Apr 2016
According to this full spec sheet, Maximum printing size of Xeed are
1. Build size single extruder (DWH) 220 x 280 x 230mm 8.7 x 11.0 x 9.1 inch
2. Build size dual extruder (DWH) 220 x 250 x 230mm 8.7 x 9.8 x 9.1 inch
Even though I definitely choose a single extruder in simplify 3D, I can print only 220 x 250 x 230mm.
Am I doing something wrong with setting in Simplify 3D?
Are there any other people who experiences same issue?
Yoshi,
Can you manually change the wide ( under > tab>g-code>build volume)
the Std function is probably not working fine
YES I know i can change width under Gcode, but that’s not issue.
Even if i set width 220 x 280 x 230mm 8.7 x 11.0 x 9.1 inch and choose a single extrude printer cut the end of printing object.
Basically I can print only 220 x 250 x 230mm 8.7 x 9.8 x 9.1 inch with single extruder
I’m looking for some people who uses Xeed and if they have same issue or not.
Maybe just spec sheet is wrong.
