Hi guys, this my second attempt at 3D Hubs. Last time I had to abort the order since the printer guy told me that they cant print fine resolution. However, this time its not going to be that way. I am interested in printing a chamber for my research using VisiJetM3 clear resin which has been shown to be resistant to the chemicals I use. Do get in touch with me. attaching the STL File. Depending on cost I have other models to print too.
Hi Sudheendra, thanks for not losing faith in us We do have several hubs printing with various types of Visijet resin: @LayerMade_1@3DStudio@3DChimera@evok3d - guys, would you be able to help with this print?
Hi, We’d be happy to give it a go, however we currently have M3 Black loaded in the machine and there is a fairly substantial chaneg over fee. I found that @3DVIX has the same machine (3500 HDMax) and being in the Miami area will probably be faster and more economical. Hope that helps. Regards evok3d
I think it’s possible to print it in Colorfabb XT transparent, but you need to check this ( XT datasheet) http://colorfabb.com/Materials/ 6 for the chemicals resistance. @ColorFabb
We have a oBjet eden260 which can print in a clear biocompatible material. If that is something, order your print her 1
Material info:
_Bio-compatible PolyJet photopolymer (MED610) is a rigid medical rapid prototyping material. It features high dimensional stability and colorless transparency. The material is ideal for applications requiring prolonged skin contact of more than 30 days and short-term mucosal-membrane contact of up to 24 hours. Bio-compatible material has five medical approvals including cytotoxicity, genotoxicity, delayed type hypersensitivity, irritation and USP plastic class VI. (Biological testing: Parts printed according to Objet MED610 Use and Maintenance Terms were evaluated for biocompatibility in accordance with standard DIN EN ISO 10993-1: 2009, Biological Evaluation of Medical Devices-Part 1: Evaluation and testing within a risk management process. This addresses cytotoxicity, genotoxicity, delayed hypersensitivity, and USP plastic Class VI, which includes the test for irritation, acute systemic toxicity and implantation.) - See more at: Biocompatible 3D Printing Materials | Stratasys
I’m also trying to print the chamber for research purposes.
I had to cancel my order due to the unavailability of this material, too.
We are trying this with 3D Hubs because it is recommended on the specific protocol called iDISCO.
Can anybody get me to the right facility that can print this chamber in VisiJetM3 Clear Resin?
Can evok3d do this? Please give me a contact info. I’m in Maryland, Johns Hopkins Medicine.
I am in the same boat as Mayumi. I want to print some small micrscope slide chambers for iDISCO in the M3 crystal resin, but my order a month ago was cancelled due to not finding any suppliers. Does anyone have this material in their printers now?
Mayumi, I’m at the NIH in Bethesda, MD so if you find a local solution to this let me know, and I will do the same!
Oh, we’re neighbors! Unfortunately, I couldn’t find any solutions on this 3D printing though I tried some other services. I’m actually putting my whole mount tissues on the glass bottom cell culture dishes with small amount of DBE at the bottom and scanning it using the Zeiss confocal microscopes. That works!
