Aug 2015
Have a look at the mankati full scale XT plus. I own a um2 and recently bought the mankati tbh its a bigger and better um2. Dual extrustion 300 degree hot ends and geard feeders. I can’t really comment on the zortax but I would say the fact you are limited to there filiment is a big turn off for me. For more details on the mankati visit our website www.fabcreator.com 4
I can’t say wich better. It depends of you wishes. I worked with both so i can give you advice:
Ultimaker:
  • Fast
  • Flexible, many material options
  • Multiple software possibilities
  • Hackable.
Zortrax M200
  • Not fast
  • Very reliable, few failed prints
  • Easy to use. Auto calibration and assisted leveling. Plug and play
  • Very good with ABS (but no PLA)
  • Very good printing results. 90micron prints are better (and easier) than 25micron on a Ultimaker.
  • Easy to remove support. It its own material. When printing with PET it’s a little harder.
  • Cheaper than a Ultimaker
  • Better build quality than a Ultimaker
Bottomline. Do you want to print fast, with special settings or with exotic materials, choose Ultimaker.
Do you want to easy print high quality objects in ABS, PET or HIPS, choose Zortrax.
I advise you to try both if you know someone who has both.
(the Mankati is also an option if you are more drawn to the Ultimaker. It’s a little bigger than the Ultimaker and it has a dual extruder.)
Translated by Google
I would just say what is important for me
It is intended for customers who are involved with miniatures (1:12, 1:87) to print their
So the detail is important for these customers
I know there are better printer but I want to deepen my not yet.
The M3D printer that I have now will not succeed with it.
In dat geval zou ik zeker naar de Zortrax gaan. Gedetailleerde en complexe prints zijn veel makkelijker met de Zortrax. Volgende week geef ik een demonstratie in Haarlem (bij de bibliotheek) met een aantal printers waaronder de Zortrax (en mogelijk ook de Ultimaker), als je dan even langskomt dan kan je zien hoe de prints eruit zien en hoe de machine werkt. Het kwaliteit verschil met de Micro is erg groot.
Op mijn hub kan je wat foto’s zien van de Zortrax prints.
Nee, bij/in de bibliotheek. Bij Multi-3D verkopen ze ook Zortrax dus daar kan je ook even gaan kijken. Ik geef workshops en trainingen met verschillende printers en ik demonstreer een paar machines zaterdag 29 augustus bij de bibliotheek in het centrum.
Je kan er ook een uitje van maken. Langs de bibliotheek en langs de winkel. Als het goed is staat daar ook een Ultimaker.
Op 28 aug ben ik bij hun aanwezig om de M3d printer samen met hun te testen
Ervaring delen want ik heb nu een M3d staan maar dat is leuk om er mee spelen maar daar blijft het bij
Oke, dan kan je de Zortrax en Ultimaker ook even bekijken. Hun Mankati heb ik momenteel in onderhoud dus die staat daar niet. De 29e heb ik nog een nieuwe printer erbij, de ZYYX. Deze is veelbelovend maar ik heb daar nog niet zelf mee gewerkt dus ik kan nog geen ervaring delen.
I haven’t a Zortrax M200 to compare but I own a UM2Ext, and I choose it for the print volume capacity and for non-proprietary material. I’m printing only on PLA. By this choice I think Ultimaler is better for me.
That depends of what you have to print with it.
Haha, nee. Ik heb voorheen gewerkt bij Multi-3D. Nu ben ik zelfstandig verder gegaan. Smart 3D werkt daarnaast ook weer samen met Multi-3D maar ook zij zijn niet verbonden met elkaar. Mulit-3D heeft de winkel, Smart de website en RADA de kennis.
Ik richt mij vooral op advies, trainingen en workshops en daarnaast reparatie en onderhoud. Ik verkoop ook printers maar dat is niet mijn corebusiness. Van Zortrax lever ik vooral de onderdelen.
Nog 1 vraagje
Wat is het beste materiaal om te gebruiken als klanten mij iets willen laten printer voor hun poppenhuis/treinbaan (miniaturen)
Deze klanten willen dan vaak iets kleins geprint hebben (1:12 / 1:87)
Voor de printers Zortrax M200 en Ultimaker 2
Alvast prettig weekend
ABS. Dat is goed na te bewerken zoals schuren, vijlen, verven en aceton-polijsten. Ook kan je het goed lijmen en het is stabiel in tegenstelling tot PLA.
Fijn weekend!
If you plan to print only ABS then Zortrax is great - very slow but good quality.
If you are willing to print PLA and never print ABS then get the UM2. It prints with great quality *and* much faster. If you are printing small parts get the UM2go - it appears (it’s hard to say) to have better quality to my eyes. I’m not convinced. It certainly is a hell of a lot cheaper.
Hoewel de ultimaker een uitstekende machine is zou ik voor de Zortrax gaan. Het feit dat er bijna nooit een print mislukt, maakt 3d printen een geweldige ervaring. De vrije keuze van materiaal van de ultimaker lijkt een pluspunt maar kan ook tot frustatie leiden om de juiste instellingen te vinden. Vaak door trial and error.
Ik heb ervaring met beide en gebruik de ultimaker alleen voor pla prints en exoten, en dan alleen met merken dat ik ken.
Zortax is de enige die ik aan kan zetten , weglopen en alleen terug hoef te komen om de (perfecte) print er uit te halen.
