Jun 2017
i have no issue printing this piece one at a time. It took about 4 hours. However if I print more than one with the exact settings I get at least one, sometimes more layer shifts. You can see the line and the supports really highlight the layer shifting. Any ideas?
So if you print one, you do not get layer shifts, but if you print two, you get layer shifting?
1. I think you should try printing slower, and see if that helps.
2. What is the model size? (I know it seems like a wierd question, but I have a reason for asking…)
Thanks for your response. Sorry for the delayed answer.
Yes, thats correct. One prints fine, anymore and I get a layer shift about 60% in. The object is 66.99mm(x) x 14.39mm(y) x 94.61mm(z - tall)…
What do you think? I can try printing slower but really doesnt make sense. If it was a belt issue I would think it would also happen when I print one…but one is flawless.
