Jun 2017
Hi @Brian_50 it can be very difficult, almost impossible for FDM printing to produce a truly watertight object. Although the surfaces may look solid/sealed, the nature of the technology. There are things that can be done with FDM prints, printing fully solid may help, acetone smoothing of ABS can seal small fissures, coating with a resin such as XTC-3D could work very well, but can be hard to work with (and expensive) and may not leave the finish you’d want (it looks like varnish).
Really you need to look at alternative printing (or production) methods to get something truly, consistently, watertight without lots of post processing. SLA or DJI would be able to achieve it, or you could investigate injection moulding - it really depends how many you want.
In terms of actual “waterproofing”, there isn’t really a material that is better per se. I guess one with better layer adhesion would be better as it would be less likely to fall apart. However, ABS might be a better option simply because it is very easy to smooth it and seal the outside of the box through acetone vapor smoothing. But it really comes down to what other properties it needs, because really any plastic with a good enough print quality would be capable of being waterproof(I have printed watertight and waterproof things with many materials). I would say that at the place where the lid meets the rest of the box, you would likely need a ring printed from flexible materials that would provide a nice seal, for the sheer tolerances on an FDM machine are not capable of producing a watertight seal. I cannot speak for the quality of other hubs, but if you would like, I can give your model a shot on my hub. Here is my link: https://www.3dhubs.com/service/245589 144
Anything printed using FDM will need some additional work to make the materials waterproof. If using ABS, an acetone vapor polish will seal the outer layers and give you a waterproof shell, and will also give you a glossy wet look (which can be turned a little more matte with some light sanding). You can also pick up some clear coat spray paint from your local hardware store, and that will give you a solid shell with a few coats.
SLA will be waterproof from the jump, but some materials will do better than others with prolonged exposure to water. All of this is assuming you are referring to water leaking through the actual walls. If you are talking about the lid, it’s gonna need a gasket.
+1
But even SLA, you need a treatment like a clearcoat on it because in time the SLA will absorb moisture.
I have printed many things that are watertight and proof, and I have never used smoothing or coating of any kind. All I do is use 4 perimeters. It works perfectly.
@Brian_50
Depending on your design, if you want, I can make it for you via my hub (www.3dhubs.com/service/mcgill 55).
The best material to use would be PETG (because it has great layer adhesion, sealing any gaps between layers).
I would use a perimeter thickness of at least 2mm and then also coat it with epoxy to ensure that it lasts.
Send me an enquiry if you are interested or if you have more questions.
