Jul 2015
Hi Arek,
Thanks for your comment! I will try printing directly on the glass today. Will let you know how it goes.
Bram
Hi Arek,
I’ve been experimenting with the Zmorph quite a bit last week and today but I haven’t been able to get any results because the ABS filament isn’t sticking to the bed. I’ve had some issues calibrating the Zmorph but I’m quite sure that I’ve got that fixed since a paper can barely move underneath it in all areas of the glass plate and the calibration tool gives the result as shown in attached picture.
I’ve had the heated bed constant at 100C. I’ve tried the glass plate, the aceton-ABS mix and blue tape. I’ve taken care of all other precautions in the link you sent as well.
When flushing the nozzles this goes perfectly fine but when extruding onto the platform very little filament seems to come out and this filament doesn’t stick to the plate but is most of the time curling up in knits behind the extruder. Do you know what might be the issue and how to solve this? Thanks a lot in any case for your help!
Bram
3 months later
This thread is a few months old already but I wanted to document my recent experiences with ABS on the Zmorph. I’m printing 1.75mm Hatchbox ABS purchased through Anazon, using the 245C / 100C temperatures (nozzle / bed). My best prints have used rafts on glass. When I remove the raft, I find that calibrating the glass flatness and optimizing the filament extrusion speed is critical to getting parts that don’t warp as much. Also - any parts with cross sections thicker than 1.5 cm with thin aspect ratios (long and thin and thick) will warp no matter what, even if I crank up the bed temperature. I can usually tell by the opacity of the printed layers of warping will occur. Layers that are translucent usually do not warp - if I see the plastic going cloudy I know the part will be twisting up off the glass soon.
My answer to ABS’s persnickety properties? I switched to PETG. The same troublesome parts in ABS print like a dream in PETG (poly(ethylene terephthalate) - glycol modified) - with no warping that I can see so far. I’m running at same conditions as ABS and I can print directly on glass with no tape, kapton or ABS juice. PETG has the toughness of nylon with the ease of printing PLA. Give it a try and you may leave ABS behind.
