Recently got a used MP200 printer. USB port poped off first time I attempted to plug in to it. I can solder but don’t think I can handle something that small. Have not gotten a print to work yet and I figure (what do I know) that maybe the problem is in the settings. Is there any way to look into the settings without hooking to a computer? This is my first printer and I have found out that it is nothing like working with my cnc machine. Should have done more research but from what I have seen on the forum, there are a lot of smart people on here so I should be able to survive. Thanks to all. Sheepdog
Ahaber
I would recommend using a micro SD card as otherwise you have to have it plugged in to your computer and your computer must be turned on for the entire time while it is printing. You will need to download Cura to program all of the settings which can change depending on material and type of print. I would recommend doing some research and watching some videos on how to do this.
