Hi again all just a quick question for you up plus 2 users, do any of you guys now or are able to find out what the pin out for the up plus 2 (v20) board is for the heater as I want to avoid replacing the heater cable wires as it would cost £50+, all I need to know is what two wires on the heater ribbon cable go to the thermistor and heater
From looking at the print-head circuit board on my UP+2. Pins 9 & 10 are the thermistor. 11&12 are one side of heater, and 13&14 is the other. Assuming the ribbon cable is a straight through.
Check the motherboard. There should be two pairs that are joined together.
Sorry I meant for the heated bed as I have managed to find adapters for the extruder I just need to get the pin out of the heated bed connectors but I think denford can supply an adapter just waiting for a price unless you can look inside your machine and post some photos which would be a huge help ! Don’t worry if you can’t though
