Sep 2016
Thanks to Maik 31 we now have a transcoder to use standard G-Code with the UP mini :slight_smile:
The transcoder is still experimental and rudimentary, using command line, no fancy GUI. This opens the UP mini to work with 3rd party slicers, use different nozzles, materials and slicing methods :slight_smile:
The source code is available via Github:
    Mar '16
    Apr '17
  • 10
  • 11.5k
  • 7
Now there’s some nice news to wake up to! Still kinda disappointed they don’t support that out of the box though.
13 days later
In order to integrate the UP mini better in a workflow with Slic3r under OS X I have created a small script app to conveniently execute all required steps from within Slic3r. So finally you can directly print from Slic3r, no need to juggle with complicated commands any more.
The project is hosted on github so you can freely access the latest build. If you feel to contribute or have suggestion for improvements give me a note. The project can be found here https://github.com/kscheff/UP3D/tree/applescript\_print/UP3DSCRIPTS/OSX
Cheers
Kai
This is solely for nozzle size, layer height and temperature this transcoder allows the use of entirely different slicers
6 months later
7 months later
