Jun 2017
Please edit your link, it doesn’t work, or use another method like Youtube :slight_smile:
go in tune check nozzle temperature and all other settings 1st … also clean nozzle again properly. send all settings details so i can help you…
…believe it or not …I did read somewhere that cleaning the sd slot with compressed air could help…so the stops could been caused by problems with reading the SD card…I did simply blow a few times into the slot - avoid spitting - …and the dammed printer is working without problems since yesterday now… lets see, what problem occurs next…
