KCT
Did u check the bowdentube or teflon tube for decay? Or the material feeder could be jammed
Thanks for your suggestions KCT: the bownden tube looks fine. I’ll take a look to the feeder and I’ll let you know!
Hi Federico, can you try to use a different nozzle to be sure that it’s not the problem?
For PLA I would recommend Tetrahydrofuran, it will clean your nozzle for any left overs. But you might also want to check the health of your isolator coupler (the white part next to the brass tube).
Can you check the thermistor? It might be not working in a good way.
We have also had similar problems. One solution is to repeat the atomic test until you get a smooth clean result. Also use a filament of another color in order to see the residue that you are removing. We have made a fine metal tool with 0.5mm diameter and made a very sharp tip. We heat up the nozzle to 260 and plunge the tool into the nozzle and work it slowly around the edges of the hot-end. I will send you a picture of our tool later. This should be done with caution in order not to damage the inner tube of the hot-end. You can also check the Ultimaker forum. 3D printing forums - Ultimaker Community of 3D Printing Experts
Kind regards,
Jaime Cavazos
Ultimaker reseller Greece
Hi Baloe3D, thanks for your feedback. The nozzle is super clean, in any case, I’ll consider Tetrahydrofuran for the future.
To check the isolator, should I disassemble the hotend from the printer?
Hi Jaime_1,
Thanks for your answer, I’ll take a look at the ultimaker forum immediately and, if I can’t find anything I’ll make a similar post there. I look forward to seeing the picture of your tool, so I’ll try to repeat the procedure with my Ultimaker.
Hey Idamartha,
I don’t have a thermometer in the lab so, honestly, I can’t be completely sure that the temperature is exactly correct. But both PLA and ABS are melting at the right temperature, so I can suppose that the thermistor is fine
Hey Alvinlab,
I’ll try within today and I’ll let you know!
Ok, I’ll try to buy one during the weekend. In any case, it’s a good tool to have in the lab
I don’t have experience with UM2, but it makes sense to remove the hot end to reach the isolator coupler. I have UM1 which should be about the same.
After you do all the easy checks…like making sure there are no stringy bits binding the filament in the bowden tube, and after checking and maybe cleaning the extruder gear, and trying a different nozzle…I would think that it is likely to be the teflon coupler that needs replacing. They are a consumable item and I have been through a couple.
MCHD
16
Try to put a litlle bit of WD-40 inside the bowden tube, it as solved my extrusion problem with the Ultimaker 2GO.
Regards
Marc
infrared thermometers will not give you an accurate reading. you need a thermistor to check temps.
Had same issue, replaced the teflon coupler. That was causing this issue and the problem was solved!
This is wat you need → http://3dsolex.com/teflon-replacements
I replaced it with this one, and the printer prints like a charm
Thanks for your suggestion, I’m quite sure that the Teflon coupler is the problem: I checked everything else and my idea it’s confirmed also by the position of the issue highlighted by the Atomic Test.
Feeder is fine. I’d say that’s the Teflon tube at this point
Agree with Brammezz as I encoutered that before, and solved by replacing a new telforn. Good Luck!
