I am using Cura 3.2.0
I tried using tweak at z to get better adhesion to the build plate. I have found that
if the first layer is set to 160% flow rate I get good adhesion. I have to do this manually with a M221 S160 at the
first layer ,Layer 0 then at layer 1 insert M221 S100. Seems simple enough I have tried Tweak a z to do this but the post puts M221 S-1.000 at the first layer which makes the extruder run backwards.
Is there a trick to make the teak at Z work . I have read many comments that say it does not work as intended. If so is there a add on that does what I need?
Ron
