I upload my STL file to select a local printer and it says the 9077.3 ✕ 7526.9 ✕ 6767.4 cm (Modeled using in) file is too big.
I change the ‘Files uploaded in’ yet I can’t get this to go through.
I’ve attached the file.
centriphone-case-v01.stl (5.7 MB)
The file has some issues in the design, run it through netfabb.
I ran it through Netfabb and now it works fine. Do you want me to print it for you? I’m also in CA, so shipping should be fast and cheap. I’ve attached the repaired file if you want to upload to my hub.
centriphone-case-v01 (repaired) (repaired).stl (9.77 MB)
always check files with Netfabb
