I’m hoping someone can give me some help as I’ve exhausted all the things I could think of.
I have a Trium 3D printer (Delta) running Merlin software. It was working perfectly up until a week ago when it crashed in the middle of a print. Once I’d got all the filament cleaned and came to use the printer again it had a very strange problem.
I zeroed all the axis and the z-axis and x-axis work fine, but the y-axis has a problem that it traverses the bed at an incline, i.e. if I lower the z-axis to about 10mm of the bed, moving the x-axis across is ok, remains 10mm, but moving the y-axis the head drops to about 5 mm at the front and rises to about 15 mm at the back. The real confusing thing is that if I raise the x-axis to around 300mm and do the same thing there either is no effect on the y-axis or its extremely small.
Does anyone have any thoughts on where I should look?
P.S. I’m suing S3D, but the problem exists in Repetier as well, both set up for Delta printers.
Many thanks
Dave
created
Aug '18last reply
Aug '18- 2
- 1.2k
