I just received my newly purchased Wanhao Duplicator I3. I would like to know if any other Wanhao users are out there, and if they have any tips for me. I just purchased a glass top for my bed, Whats the best way to secure it to the main bed, etc…
its amazing to me the upgrade parts you can print the fan braces would stop it from hanging so low. I have been using pla, I just did print all the thumb screws for the print bed just have to get nuts at the hardware store.
Hello! How fun that you decided to buy a Wanhao i3. I got one myself this monday and have been using it non-stop since. Check out this video with the perfect settings for the Cura slicer. I have been using these settings on every print (I have changed the layer thickness on some just to try out a more even surface) and it works really good every single time!!
I’m sure it will work. Or just go to the hardware shop and ask them to cut you some normal glass to put the PEI on, before you put PEI on the borosilicate
It doesn’t seem normal that your Z-Axis goes out. Are you sure it’s the axis, and not the bed? I also use the 2 little printed Z axis alignment posts that some posted earlier in the thread (http://www.thingiverse.com/thing:1138928 2), and in 5 months I have literally only had to recalibrate my Z-axis once (after traveling with the printer).
After printing, when you check with the alignment posts, are they at differing heights?
