Jan 2015
I do not agree with your last point. When you’re saving a model in Cura it will be saved as a STL file when you put .stl at the end. If you don’t add .stl it will be saved as an AMF file.
Now you can delete the last point from your “Annoy List” :slight_smile:
Thx that’s true I should have try that but wrongly assumed the proprietary extension was associated with a propriatory encoding. But why not offering the options in the user interface instead of hiding it for the end user to find it by chance or by try and error.
I should also says that Slic3r do have this functionality as Export STL button on the GUI. Sorry if you felt offended but this is not an “Annoy list” The comment clearly stated few missing feature and not things that a re missing that I’m bothered by. :wink: Unfortunately comment are not editable otherwise I will have amended the list.
Cura3D can export gcode for use it in a SD card directly on the printer, I have not found this option in MatterControl?
point: Ability to set different temperature between first layer
yes there is, Plugins tab -> Tweak at Z
and you can add more plugin like Skip infill that print external layer to hires anhd infill to 250
Don’t get me wrong, i’m not offended at all! It is because you said “I must miss some things that annoy me” why i chose to put it that way :wink:
Nice thx Christian for pointing this out. I’ve used “Pause at height” before but never investigated the other plugin.
13 days later
10 months later
The optimal settings for faster/better prints will depend on what you are printing and the material you use. I recommend playing around with the recommended settings, making sure to change one setting at a time and document this so you can go back to it and see how each adjustment affects your print. An article on the Pinshape Blog 3 also recommends printing 20mm cubes to get the hang of it. It’s boring but it will make sure your printer is well calibrated & gives you a chance to play with settings without wasting a ton of filament.
I tought it only happened to me but Cura indeed has it’s weird moments. It is rare but still, when you’re in the middle of a print and suddenly you hear the z-motors accelerating to full speed. The extruder goes up and then it goes down and plunges into the print to go up again and ruin the print. It angers me enough to return to Slic3r a couple of weeks until I have forgotten about the incident. But overall it does happen only rarely and Cura does it job very well.
