Jan 2015
I do not agree with your last point. When you’re saving a model in Cura it will be saved as a STL file when you put .stl at the end. If you don’t add .stl it will be saved as an AMF file.
Now you can delete the last point from your “Annoy List” :slight_smile:
i have also been using cura for some time now for my UM1 and also tried other stuff now and then.
cura i believe is the single tool which can cover a sufficient number of home-enthusiast. two reasons to work on others :
1) detailed and customized supports. i ended up using b9creator’s slicing software to create thin stick supports
2) variable layer height. great tool for optimizing print time. slic3r has it but i do not think it is a must-have if you are in the first 3-6 months of your 3d printing journey.
if i have time i will also take a look into creating plug-ins but i do not believe the main structure of cura will allow multiple layer heights.
I use Cura and Simplify3d but still can’t get used to Simplify3D. Cura is so much more intuitive.
When I print many small parts in one run I put on the fan for the first layer on my UM2. Otherwise the nozzle’s temperature is going up and down resulting in blurry melted pla or non-sticking pla to the glass.
What I love about Simplify3D is the fact that you can set up different settings for different parts in the same run.
13 days later
10 months later
The optimal settings for faster/better prints will depend on what you are printing and the material you use. I recommend playing around with the recommended settings, making sure to change one setting at a time and document this so you can go back to it and see how each adjustment affects your print. An article on the Pinshape Blog 3 also recommends printing 20mm cubes to get the hang of it. It’s boring but it will make sure your printer is well calibrated & gives you a chance to play with settings without wasting a ton of filament.
I tought it only happened to me but Cura indeed has it’s weird moments. It is rare but still, when you’re in the middle of a print and suddenly you hear the z-motors accelerating to full speed. The extruder goes up and then it goes down and plunges into the print to go up again and ruin the print. It angers me enough to return to Slic3r a couple of weeks until I have forgotten about the incident. But overall it does happen only rarely and Cura does it job very well.
