In replicatorG is there a way to add the support pad that prints when you use support/rafts without adding in the rafts?
I was wondering if there was a line of g-code I could add ontop of the model.
I’m having a problem with the first layer of complex objects where the print jet will sometimes snag the base layer of plastic and ball up. I never have this problem when using a support pad.
