Dec 2017
Hey guys,
You helped me figure out my last issue, so hopefully you can help me with this one. I’m using a robo r1 plus with simply3d, my issue is when I print something with supports the first layer after the support is crappy. I’ve been playing with settings on the support side but have had no luck. here are the support settings I have.
Support infill: 30
Extra inflation distance: 1mm
support base layers 0
combine support every 1 layer
dense support layers 4
dense fill: 90%
support pillar resolution 1mm
horizontal offset from part: .30mm
upper and lower vertical seperation layer 1
Any help would be appreciated!
Can’t really see what your trying to print but Have you tried increasing the mount of top solid layers? This can be found in the Layers tab in S3D
The part you see is actually the bottom layer, the part I just made up real fast to show what issue im having. All it is, is a L shaped so I can use supports to show. The first layer after the supports is the issue.
Well if it’s just an L shape why don’t you print it flat on the side without supports!!!
That’s obviously extrusion problem. can you print just one layer 0.3mm 10x10cm without any holes/gaps in it?
