Jan 2018
7 months later
possibly
if you open the cover, see if you can feel any air flow from the two UV fan funnels
If you get a torch you should be able to peer down them and see the two (per UV Lamp) fans
If the printers on, these should be running,
If one or more isn’t, check the connections (white plug with red, black, yellow etc wires), voltage (24vdc).
What kind of temps during printing are you seeing?
