I’m using solidworks to convert my files to .stl. However, there’s a limit on setting the deviation and angle. (Max deviation is about 0.2mm) I need a low resolution stl export. (Yes, bad quality) Is there any software availabe which lets you customize the deviation? (Without limit obviously)
Thank you for your reply. I might have been a little bit unclear. But I need the deviation factor to be about 2mm. (So it will be a very small, and bad quality file) However, Solidworks has a limit. So the deviation range can be set from 0.2 till 0.001mm or something like that.
