Dec 2016
I would second this. Biocompatible materials are still mostly relegated to high end industrial machines, but the Formlabs Dental SG resin is probably the most accessible and available bio compatible material for consumer printing. If you contact a Hub with a Form2 printer, they might be willing to special order that resin for you (if they do not already have it), but it is pretty expensive stuff comparably. Best of luck!
It is a resin I only stock for special orders because of that price tag. But from what I’ve seen of it, it prints beautifully and works exactly as it is designed to.
Did I say “only used by”?! I said “commonly used by” big difference… besides when you see hospitals and even vets using 3d printing is usually done in titanium… so when I read the original post I thought it might be some 3d printed Piercing type jewellery.
12 days later
Going forward in my project, autoclave seems like one essential requirement… I will definitely look at the possibility to manufacture using Nylon.
Thank you for the input
We decided t go with Autoclave. That forces us to look into Nylon or other material than can handle autoclave temperature.
As mentioned, Taulman’s Nylon 680 is one of your best options - Nylon 680 Spec 117
It’s FDA approved and autoclavable, but may not be approved for your particular use. Taulman may have additional info that may help you decide.
Thank you for the input.
The only medical grade (bio-compatible) material i find from Taulman is Guidel!ne.
And it seems like you can not autoclave it…
Yes! PA2201 and 2200 is biocompatible according to ISO10993 and you can autoclave it.
Thank you for the input. I will check what degree of bio-compatibility is needed exactly for my device.
Also “EOS PEEK HP3” seems like a possible choice.
It’s not a problem, I know that PA2200 can be used in making medical cutting guides, but if you are looking for a material that is implantable you would have to run tests and studies.
