I’ve been putting together my 3D printer for about four months now and am almost complete but I’ve run into two problems that are the same no matter what program I use (Cura, Repetier, etc…). At the beginning of any print the printer goes through the auto level process, heats up, and then goes way off the print bed(to the point where it can’t go any further because it runs into a post) for a quick fix I changed my print area to about half the size so it doesn’t go as far but this is definitely not a final fix. After this point the printing head proceeds to run the gcode and it looks like it’s doing the right motions but it is about 3/4 of an inch above the plate. I have a Flsun kossel delta if that helps at all. I would greatly appreciate any help with my problems, Thanks! (see the attached pictures for a visual.)
