The Benchy did ok. Not perfect but passable. I need to figure out why I am getting these rough edges like this. I am running the same print on another printer with stock MK10 setup to see how that does compared to the Micro-Swiss set up.
Another option is to use PETG, which doesn’t have the same warping problem as ABS, and is quite tough. It’s a bit more flexible than ABS. For your application I’d use PETG.
Rotating the part is really not an option since the other side is completely curved and would require numerous supports and the surface would suffer. Good option in other cases though.
If I do perimeters first the issue will be worse since the first perimeter will have nothing to hold to do to the overhang!
My printer is pretty much on-off for the fan but using it has actually helped I think. Printing with the right side and the fan on the left is not so much of a direct cooling and it seems to have responded favorably.
FlashForge Printer and it is enclosed. This I think has help with the use of the cooling fan since the ambient is so high the fan only has minimal effect since it is moving hot air…
Another thing I did was reduced the extrusion multiplier. I found that what worked for the stock (extrusion multiplier ABS default of 1) set up seems to be way to much now. I have dropped to .89 and I think I am gaining on the problem. Also slowed a bit which is painful when the print is 13 hours to start with!
