Skip to main content
What are your print settings? Material? What slicing software are you using? First glance, it looks like the layer height is really thick, but it will be easier to figure out what’s going on once we see your setup.
25 days later
Make sure your belts are tensioned enough! I had the exact same issue and tightened up the Y axis belt and fixed the problem just like that. Good luck !
