Nov 2015
Man I’ve searched everywhere and have not found an answer. I’m using Simplify3D, I want to Import a collection of Objects and Print ONLY the selected objects. When I prepare to print and go into preview mode, not only do I see the 1-2 or 3 selected parts but I see ALL darn parts.
Any Ideas any one?
    Nov '15
    Jul '17
  • 2.3k
  • 3
Are all objects separately imported (multiple stl files)? If so then go into the advanced settings and click on the button in the bottom left of the opening window. The next smaller window will enable you to select just the models you want. When all models are included in one stl files then you need to edit the stl to print just one or a few models, Simplify3D can only decide between multiple stl files, not between multiple models in one stl. Cheers, Marius Breuer
2 years later
Go to “Mesh” menu and select “separate connected surface” and it will divide all disconnected objects and make it into separate stl files. Good luck!
