May 2017
What OS are you using? PC spec? Checked the Install requirements? 32 / 64 bit System?
I am using Windows 10 pro version on a intel 2.30 system with 6 gigs of ram 64bit.
Most times when installing something on Recent Windows platforms a “Yes/No” dialog will open that you must respond to in order for the install to continue. It is possible this is getting stuck behind a window.
Another thing is to install with Administrative permissions. Generally you can right click on the setup file and select “Install as Administrator”.
Also make sure no anti-virus, spyware etc. program is running.
