patrick i thought you where running with the simplfy slicer, ther you van adjust your fan speed per layer!
Skip to main content
Hi Maarten
do you use fan to print with ABS?
yes, My fanspeed is on 60%
Hi Patrick
try to change temperature down to 220 deg and also I would say could be overhang issue as curves making makeing it over 45 deg
I would split those and print them on sides not like you have done
Let me know if its helps
Regards
Adam Malkowski
9 days later
