Skip to main content
Hey @PATRICK_43
Simplify3D Has actually released a really handy guide on printing errors like this : Print Quality Guide | Simplify3D Software 107
Make sure to check it out
@Arnoldas is correct, check the guide. Also your temperature looks to be off. It could be related to print speed or cooling. I’d recommend printing a temperature calibration tower to see if you can dial in a better temp for that filament.
Lower the layer ,15 mm or lower infill full honeycomb en outer layer perimeters 2
and oh try some different position an take a look at the previews, cooling can also be an issue.
if the last part are small print runs per layer you should increase cooling, you can change this in the coolingsettings
9 days later
