My company are looking to find someone that can 3d print in silcone for a range of watch prototypes. I know that this is a reletively new material to print in but I know there are printers out there capable of doing it and add on’s available for 3d printers that allow this. Is there anyone out there doing this or have any contacts of anyone doing this.
Not many printer can print silicone, but do remember that silicone is very hard to post proces, and any structure in the print will not be able to smooth out.
if you are looking just for cheapest test parts, and don’t care for the structure, then this is the ways to go.
otherwise you will get better results to have the object printed, and have molds made to cast in silicone, or polyurethane rubber.
it is more time consuming and costly.
but you could also look for printers that can print flexible PLA, I have seen some good prints with this material.
and when you want a lot of prototypes, or limited range of won devoloped / designed object, you could even consider investing your own 3D printer
I’ve looked at this method and it looks to be quite sketchy and rough even when casting has been fairly sucessful. Direct silicone printing looks like it gives much better results.
Printing in Silicone can be done using a paste extruder machine. However the layers are not so neat and often gets broken or results in deformation due to the property of silicone to expand. We have a patent pending machine that can print in Silicone successfully. We have succesfully printed many products in Silicone. We can help you make your prototype.
As copenhagen says we are 3D Printing silicone, without support material, no post processing and at a resolution of 400 microns. Currently we have a test rig and we are looking for circa £300K to develop the technology to a point where we can achieve sub 200 micron resolution with variable Shore Hardness A in a single build. Follow us @picsima on Twitter and our website www.picsima.com 53
I have seen this on your website already and watched a few videos on youtube. Are you at a stage where you are printing for customers etc? I’d be interested in sending you stuff we’d be looking to get prototyped in silicone. We specialise in silicone watches but it would be a real advantage to prototype in this material before we get moulds made. This is our website www.breo.com 28 Have a look and let me know if you think we could work together.
See the images i made for a customer. It is a flexible damper for a insertbearingblock and it looks Ok . It won’t be as smooth as the watch you sell because of the somewhat lower resolution. but i will do for prototypes
Hello @picsma. Very impressive. Is it the kind of technology that’s likely to result in a moderately priced desktop printer or is it inherently bulky and/or cost prohibitive for smaller sized printers?
Yes. It has a certificate for use in medical situations, visit the Recreus web site to download it. The material seems really tough and the bond between layers is strong, so I would expect it to be good for these applications. The problem with the material is that it is difficult to print using a standard print head, that is why we have invested in a custom made machine designed to use it.
@picsima: Hi, I too require a part to be printed in silicone. Checked out your website and was wondering what is the maximum surface finish you can achieve because as far as I have heard 3D printing silicone might not have a very smooth surface finish.
Because we are very well versed in silicones, we DO have silicone material that we HAVE 3D printed. We can do prototypes, or 100s of units. Let me know if you are interested in having us do your product.
