For the Venus dock assembly, would that part be included in my CAD model and printed along with the handle or should my design fit into that piece i.e. be it’s negative. I am using Solidworks.
Thanks
Hi Anna,
You only have to design around it, as we will fit that part into the cavity once we receive your design.
Hope this helps!
Regards,
makersCAFE team
i am currently trying to create a part that slots in nicely, but as the dimensions are so tiny will the 3D printers be able to produce the level of detail required?
Thanks for your help,
Anna
Hi Anna,
Just wanted to say that if you look at our Instagram account (@rzrmkr) you’ll see pictures of the dock assembly parts we will provide.
As for the printed cavities; our tests here have used an Ultimaker2 and we’ve found that the cavities print really nicely and fit the precision parts well. Keep the print orientations in mind, and good luck!
Let us know if we can help with anything else!
Regards,
RZR MKR team
