Agreed with many post Definitely look to simplify 3-D It’s worth every penny being able to control your Your print in real time is amazing and previewing the print before you start save you so much time
I have had the best luck so far with 0.3mm layer height. The 0.1 comes out messed up usually. One thing that helped me a lot was heating the bed and using glue stick. You may want to decrease bridging speed to improve the quality on the front of the cabin.
I’ve found than thinner layer heights help, and good cooling is important.
On my printer I have plenty of insulation protecting the tip of the hotend from the PLA cooling, and there are three small blower (centrifugal) fans to quickly cool the PLA.
These were printed at 215C in black PLA at 60mm/sec. I think one was printed with a layer height of 0.05mm and nozzle width of 0.25mm, and the other with a layer height of 0.1mm and nozzle width of 0.3mm.
What meant by the extruder pushing down as that the where the two walls of the hull meet, the point would start lifting (maybe caused by expansion?) and the extruder would push it down as it was extruding the next layer. This caused globs to form at the point. Probably is a cooling issue.
“The extruder seemed to be pushing the front end down while extruding which made it look terrible with odd blobs all over the front end.”
You might want to check the screws holding the cooling fan, stepper motor and extruder gear in place. I do not mean the cooling fan at the nozzle, I mean the cooling fan at the extruder gear. They might be loose. I’ve had loose screws there causing the entire hotend and extruder assembly to vibrate or rotate, especially at higher speeds.
