Iamtj
Hey guys just had a question. I hired someone on Shapeways to make a 3d design for me. The issue is when i upload it to Rhino the measurements are a little different and the designer says that is normal. I have added an attachment so you know what i mean.
Is this normal ? Thanks.
Xeno
Rhino should be accurate,
deformation because you open it in another CAD program is a bit silly, it could have some differences between files, but only scaled deformation,
you normally should be able to create a box around it, and scale/stretch it to the correct proportions, but these differences in an intersection of a model is not something that could/should happen.
What kind of file was supplied that you opened in Rhino ?
Iamtj
Thanks for the reply. I imported it from 3D builder. Maybe i can send you the file and you could tell me the dimensions ?
Indeed, if just a smal part of the design is different than it’s most likely a design error by the designer probably. Otherwise if the whole object is out of scale could it be a solution to do the math and to apply a “uniform scale” on the whole object? What software did he make the design in? Could it be inches versus Millimeters? And selecting a wrong checkbox during importing or exporting the file (him or you)? … gr. Frank
Hey.
Accuracy at 1-10 micron occurs when transferring files from one program to another. Accuracy of 0.25 is a lot. Whose mistake))
For correct operation is better to use the same program.
Iamtj
6
Ya actually it is very close to the size it is supposed to be and we are both using mm. I think he used 3ds max. It opened on my laptop on 3d builder since i use windows 10. I imported it to Rhino to see the dimensions but he is tell me they are wrong.
Turns out i was right and the guy was wrong, i got someone to fix it. Thanks for the help guys.
Your welcome, I even tried to measure it for you in Fusion360 as you can see …something went wrong with designing. Good luck …
gr. Frank
