Feb 2016
This might help with Pronterface-
1)In your firmware you have a minimum extruder temp. That keeps a printer from starting until the extruder is up to temp.
Find that value and change it to 0.
2) Upload firmware and re-launch Pronterface and see if you can start calibrating your printer.
3) If that worked make sure you go back and change the min temp in your firmware and upload again.
(Not sure its really necessary as most software waits to hit the temp you set in your slicing/printing software but…why not?)
Another question : can you read extruder temperature on the PC software ?
Are you sure you’re connected to the right COM port ?
Thanks for the upload,
That is weird. Let’s try this…
Disconnect power, take only the working motor and connect it to a different motor connection. From the configuration.h file it looks like you have a RAMPS board. So if it is X move it to Y or Z.
Leave the other motors including the extruder disconnected and try to move that motor using the control for that axis you hooked it to. If it works,move it to the other non-working axis. I’m pretty sure the extruder motor won’t work until you get to minimum temperature with the hotend, but don’t worry about that yet, we are fixing X,Y,Z for now
If both axes work using the “known good” motor that shows the drivers are functional. Now it’s time to connect the “non-working motors” one at a time to make sure they work.The orientation of the connector on the board will just reverse the direction of the motor when it spins. Just take a look at the color sequence of the wires on the working motor and make sure the non-working ones are correct…
Here is a pic of the A4998 driver chip for your stepper.
That is usually the one they ship. There is another type that is more robust but that is usually an optional thing. The round shiny circular metal object on the right is the potentiometer, See if they are all set “roughly” to the same orientation as the “working” one. Without a meter that is a rough guide to get them close but not completely accurate .
I don’t want to overload you with things to check, it would be better for you if you had somebody with a 3d printer that you knew who could give you “hands-on” help, It’s tough to diagnose over the web.
If the working motor does not move on the non-working connectors it could be the driver board itself.
Here is a pic of the RAMPS board with the driver boards.
Is that what you have? The stepper connections are above the driver boards from Left - X Y Z
from top Left Extruder 0 Extruder 1
If it came with 5 you have a spare driver board.
Let me know what happens.
I went through the diagnostic process you described. X, Y, and Z all seem to be functional with the known functioning motor. When plugging in the questionable motor, it behaved the same as before; seeming to whir/grind, but not spinning. I have ordered a new motor to replace this, so hopefully things will go better after that. Thanks for all of your help!
To your last question, I believe the drivers are integrated, as there seem to be no removable boards on the MKS Base v1.4. You can see a photo of it here. Sorry, it’s not a great view.
OK,I see.
Your configuration.h file shows that you have a RAMPS1.4 selected as your board - define MOTHERBOARD 33
I just looked your board up and it is firmware compatible with the RAMPS 1.3/1.4.
Make sure the pins are pushed all the way into the connector when before you plug it in.
There were no instructions or downloadable files with your build from the manufacturer??
Good Luck! If you need more info after you get your replacement motors, we are here.
