Lumia
Hi, could anyone help me with leveling and calibrating rf1000? not good at engineering…Thanks!!!
Lumia
Thanks but I can’t read… any English translate or videos?
kedam
Hi Lumia
Got an English version for you in PDF as attachment
It’s quite easy.
Just make sure you set the temperature from the bed on 100 degrees Celcius
Wait until the bed is 100 degrees.
Make sure you have a filament inserted into the extruder
( for the correct weight value on the loadcells)
Do .NOT. put any masking tape on the bed.
Push configuration > heat bedscan.
takes about 10-15 minutes.
When it aborts simply try it again.
otherwise you need to readjust the limitswitch of the Z-axis
RGDS , T L.
001007507-an-02-en-AB_08_14_RENKFORCE_3D_DRUCKER_BAUSATZ.pdf (54.5 MB)
Lumia
6
Hi TL,
Thank you very much and yes I need to readjust the limit switch of Z-axis, It’s too close to the heat bed. The problem now is how to open the base steel covers?
Why would you need to open the steel covers ?
The adjustment for the limit switch of the Z axis is an m3 screw ,
mounted with a locknut on an extension pillar on the Y plateau.
Page 44 an page 54 of this manual
When you let the bed down and to the front you can see it on the right side behind the bed.
Good luck , T L.
