Nov 2015
You had an axis shift, towards your endstop, and your assumption is firmware? This is not a firmware bug, this is a failing endstop cable.
Hi Adam, Hmmmmmm… Ok, I jumped the gun there. I was browsing the LCD Menus when it happend, and put 2 and 2 together and got 5, having only recently got the Firmware Installed… I let the printer run after and spotted the problem. The filament some how was working it’s way in and out of the cable clamp on the back of the machine, and then clearing it’s self when the Carriage moved towards the back of the machine. I’ve fitted some guide tubes now to stop it happening. I suspect the Filament jammed, and restricted the carriage movement but had cleared it’s self by the time I checked it out.
I like SailFish VERY much…
