Feb 2017
Perfect condition, very large 12x12x24 inch build volume. Full working thouch screen, easy to use out of the box. Amazing build quality perfect for your large projects.
    Feb '17
    Feb '17
  • 8
  • 3.1k
  • 5
Absolutely love my Raise3D N2. Fantastic print quality, huge build volume. Only thing I don’t like is how the filament is fed into the printer. Has to fight gravity too much but doesn’t seem to effect print quality so whatever. Phillip, just FYI, that won’t effect print quality as long as the barrel and the nozzle are properly joined but all four of mine do not rotate. Based on the cleanliness of your extruders too, it looks like you have have abused the extruder causing it to come loose. Luckily it’s easy to replace if it bugs you.
If that was your first print, then the user error is even worse. There’s no way that the material can cake on there and burn like that without negligence.
That’s horrible! you should absolutely sell it! I will offer you 1,000 to take that scrapheap off your hands. ( It’s for science!)
