Hi Trevor,
I am able to help you here. Just so I can understand what your needs are more, What is it exactly that will be going through the holes on the corners? Are they holes for bolts? Also is the centre meant to be hollow? I have started to design this so you can see it in a 3d model.
Hi Trevor,
Please find attached your design in STL format. Please note due to the size of it you may struggle to find someone with a printer big enough to get this done in one piece. If it is not necessary to be done in one piece I will happily have this printed for you.
Please note there was no radius specification for the holes in the corners so I used 8.5mm. I also chose a 3mm thickness over a 2mm thickness purely for strength.
Please feel free to contact me at any time if you need anything else designed or if you want anything printed. My Facebook page is;
Instagram;
https://www.instagram.com/that3dstore/
and of course my 3d hubs page is;
https://www.3dhubs.com/brisbane/hubs/3d-store
Thank you
Nathan
nathanclinnick@gmail.com
Trevor’s part - Part Studio 1.stl (23.5 KB)
Hey Trevor,
first step would be to look and see which hubs offer CAD services, and go from there.
i do personally, and can provide tax invoices as a registered ABN holder.
feel free to check out my hub and others’ as well to see what we can do, and I’m sure there’s a way to directly message or send enquiries.
Matt
hi trevor i am able to print this object in one. if you need it to be printed please contact me we have 3 printers 2 have a bed size of 300x250x530 and one at 300x250x330 in august of this year we take delivery of a printer that has a bed size of 1.2 metres x1.2 metres x2.4 metres so any big prints you have we can do them thank you rick 3dwise
Hi Trevor,
The size of the part will probably not allow you to print on most desktop printers as Nathan mentioned below. The print area size on most printers is about 290mm x 200 maximum. A few questions to find out a little more:
- Is this part a hood of some sort? (i.e. does it have a solid top?)
- Is there a skirt around the bottom of the part? If so what thickness does this need to be?
- What material does this part need to be? A hard plastic like material or a more flexible material? We can print both options.
If this is something that you need in one piece we can still accomodate you by using a more traditional subtractive manufacturing method (Waterjet Cut or CNC Router Cut). Happy to discuss either and suit your timing and budget.
sales@queenslandgaskets.com.au - 07 3277 3922
Look forward to hearing from you.
Queensland Gaskets - Jamie
Hi
can you please contact me to discuss
07 5494 2619
text 0400 440 551
Thanks Trevor
Please contact me when you are free
Wanting to get this underway ASAP
Regards Trevor
Ph: 07 5494 2610
Text: 0400 440 551
e: enjoy7@bigpond.net.au
Hey @newbeams, the best way to do this is go to Online 3D Printing Service | Instant 3D Printing Quotes | Hubs, upload your files, fill in your location and further filter out the results if you need a certain material or printer for your prototype. If you also need CAD modeling services, be sure to tick the Can help with 3D modeling under the More Filters button. Hope this helps!
Did you manage to find a Hub yet? Please let me know if you need any help with that. Cheers
Hey Jamie, thanks for the input! Moving forward, please feel free to add a link to your Hub profile as well, so Trevor can see some sample prints before placing an order at your Hub. Cheers
Yes i have found a hub
I’m hoping it works out the guy seems very helpful and has made the process so simply for me as a first time user
If you need someone to design the product in 3d for you, look at hubs that have modeling services and then send them a message asking for a quote to get the design modeled in 3d.
