Jan 2015
Hello, I have been trying to upload my file for a quote, it is telling me the file is to big and I notice that it cm, I have been requesting inches.
Hi Markus, thank you for getting in touch with us.
I checked out your model and it looks like you might have modelled the file in another measurement unit than inches. Can you tell me what size the model is supposed to be? Then I can scale it to the correct size for you and you shouldn’t have any trouble uploading it to 3D Hubs
Not at all, it’s perfectly printable. If you upload the model to the website and go to www.3dhubs.com/3dprint you will automatically receive a list of Hubs that are able to print the model. The printers with a building plate that is to small for your model are automatically filtered out of the results.
This is where my problem began, I uploaded to the HuB and nothing popped up in my area or even unlimited distance that would be able to print for me. Can you help?
Hey Markus, did you try uploading the model I attached to my previous post? Please make sure you have mm selected as your measurement unit (which is the default setting). If you still don’t see any results, please contact me via robin@3dhubs.com and we’ll get this all sorted out :slight_smile:
