Dec 2017
In addition to the belts and tensioners on each side, you should also double check where the gears and bearings attach in the upper corners. My Creator Pro was dropped during shipping and it knocked the gears and bearings in the upper front corners loose causing them to track sideways. You can remove the plastic side panels from both sides by removing the screws that hold them (careful with the left side panel as the Y-axis endstop switch is attached there). And then you will be able to see into those corners to check yours. On mine, once I removed the panels I was able to press the gears and their bearings back into the holders and snap them back into position. Then, do as the others described here and reposition and retention the belts connecting the gantry and it should be as good as new…
