hello, 101hero the printer had a problem i guess. I print with simplify3d. and infill value is 100%. Looks like that in the picture. this situation has just occurred. and I don’t know why.
Hi, could you post the picture again? It hasn’t gone through.
Thanks. I send picture.
There’s a lot of issues going on here. Unfortunately it’s going to be hard to figure out which are the printer (since it is the least expensive on the market, and doesn’t use standard components) and which are your slicer settings.
I would say you need to lower you temp about 10c, slow down to 10mm/second at maximum, and then see if that helps.
