Selling my QIDI Tech I 3D printer with lots of upgrades-
Thanks to the upgraded all-metal Micro-Swiss hot-ends ($80 USD retail), it can print any filament (ABS, PLA, PETG, Nylon, Carbon Fiber, etc.) out there without requiring hardware replacements every few prints.
Thanks to the PEI sheet upgrade ($35 USD retail), you’ll never have to worry about applying messy ABS slurry or gluesticks on the build surface. The PEI sheet softens and grabs onto the print while the plate is hot, and lets go of the print easily once it cools down. You simply have to clean it with rubbing alcohol from time to time.
Upgraded part cooling fan ensures even distribution of air for better cooling performance
Added masking tape for better environmental control and dust prevention
Aftermarket Support: This printer has a vibrant and responsive Facebook community and in-house support. You can also contact me with questions or concerns. I’m an active member of the 3D printing community, and I’d be happy to point you in the right direction.
Price: $650
Delivery: Free delivery, installation, and testing in and around the island of Montreal
Note: Sale includes all stock printer hardware and upgrades. It doesn’t include pictured Raspberry Pi, camera, power strip, etc. hardware that didn’t come with the printer and are not a direct upgrade to the pinter.
Reason for sale: Need funding for a new project
Qidi Tech 1 specifications:
Technology: FFF FDM
Assembly: Fully-assembled
Mechanical arrangement: Cartesian-XY-head
Manufacturer: QIDI TECHNOLOGY
Certifications: CE, FCC, RoHS
Printable materials: ABS, PLA, PETG, HIPS
Filameter diameter: 1.75 mm
Compatible with 3rd party filaments? Yes, an open material system
Build volume-
Print size millimeters (XYZ): 230 x 150 x 150 mm
Print size inches (XYZ): 8.8 x 5.9 x 5.9 inches
3D Printer and printing properties-
Layer resolution: 100 - 300 Microns
Feeder system: Bowden
Extruder type: Dual
Nozzle size: 0.4 mm
Max extruder temperature: 482 °F / 250 °C (>300°C with all-metal upgrade)
Max heated bed temperature: 230 °F / 110 °C
Max print speed: 60 mm/s
Closed print chamber: Yes, fully enclosed
Print bed details: Heated bed
Display: LCD
Board: Sailfish 7.8 version, ATmega 2560
Connectivity: SD, USB cable
Outer dimensions inches (XYZ): 18.3 x 12.6 x 14.8 inches
Outer dimensions millimeters (XYZ): 465 x 320 x 375 mm
Weight lb: 55.1 pounds
Weight kg: 25 kg
