I have a flashforge and 3 Power Spec 3d printers, they are all the same printer, the QIDI is the same as well. In fact, I just order QIDI parts for repair of my printers, just blew a motherboard and bought a QIDI motherboard, works like champ!!! Qidi ships FAST and never had a problem in the 5 parts orders I’ve placed.
A word of caution, those printers have an aluminum bed, it will warp - it’s not an if it does, it will. I run this glass on top of the aluminum (don’t put on the plastic top or take the plastic pad off the print bed.) https://www.amazon.com/Borosilicate-Glass-Upgrade-Flashforge-Creator/dp/B00XWLVKRG/ref=sr\_1\_3?ie=UTF8&qid=1481715520&sr=8-3&keywords=flashforge+glass
You can get cheaper glass, but that glass is 1/4 inch thick and I’ve yet to break it (and I’m rough on stuff).
Here is the best thing about a glass bed - clean it really well, then put a layer of hair spray on it. When you print PLA, heat the bed to 60, after you print, let the printer bed cool off and the part litterally pops off - no joke, it’s bloody amazing! And I’ve got or have tried almost every print surface out there - it’s glass and hair spray for me.
I would also recomend adding a raspberry pi and Astroprint which is capable of running these printers - you slice and print through Astroprint (only prints one extruder) or upload your x3g file directly to the raspberry pi and print. I generate alot of prints in Simpily3d and upload them, other days, I just print via the web interface.
And you must print one of these and install it on the back -Flashforge Creator Pro Filament Alignment Bracket by Makersome - Thingiverse that makes the filament run so much nicer off the rolls! And these for your wing nuts http://www.thingiverse.com/thing:604579
I have 4 of these printers, love every one of them!!
I have both the QIDI (2) and the FFCP (2). Both great machines especially starting out. They are straight forward with minimal set up to get going. Lots of support around the web including here. Both dual extrusion and enclosed which is a big plus for filaments like ABS.
The weight is probably due to the QIDI being all metal including side, front and back panels where as the FFCP panels are plastic.
Both side and front clear panels can come off the QIDI. ON the FFCP the door will come off and only the right panel. The left panel will come off bu the Y limit switch is on it so it has to stay in place.
QIDI support is excellent.
I am partial to the QIDI because it was my first printer.
like you after exhaustive research it was down to these two and the reviews were really liking the QIDI as the alternative to the popular FFCP. When I got mine it was $400 less!!
You won’t go wrong with either. I would have no issue getting the QIDI.
Where did the “akowski” come from?!! At first I was thinking it was another clone until you mentioned the wait time.
Bah, dang Apple autocorrect! (and lack of proofreading before clicking [Submit]). Fixed, thanks.
I literally just bought the QIDI Tech 1 for a specific purpose, it is my 4th printer. I also have a Lulzbot Mini, Lulzbot TAZ 6, and a Monoprice Select Mini
i needed the dul extrusion capability pf the QIDI. I actually bought the Flashforge on Amazon then almost immediately cancelled the order and got the QIDI, remembering it was the same printer.
I honestly don’t know about the weight difference but I can vouch for the QIDI being 50lbs. It is built like a tank, all metal. There is some assembly required (instructions are in the SD card inserted in the printer).
Are you dead dead set on these two printers? The only reason I ask is because if you were already considering the FF you should look at the “Original Prusa i3 MK2”. It is $899 for an assembled and calibrated printer and is agreed by many as THE number one 3D printer you can buy today.
The only downside side is there is no way you will be able to get it for him by Christmas. The printer is in such demand there is a 6-8 week backlog. If he can wait, the printing experience will be superior. Not knocking QIDI, I like it and I’m sure he will too, but for just a little bit more you can get a really great printer.
Something to consider… Here’s the URL
http://shop.prusa3d.com/en/3d-printers/53-original-prusa-i3-mk2-3d-printer.html
Didn’t mean to upset the Apple cart. But you’re already looking to spend about what the Prusa costs and there’s literally no comparison. The only downside is having to wait.
HAHA! Had me scratching my head on that one!
I also compared the 2 models and have never regretted my decision. I went with the Flashforge Creator Pro. Bought if off Amazon and loves it!! Loved it so much that we bought a second one. Hope that helps you make a decision. Happy Holidays!
Get the Flashforge Creator Pro!
bobo123
15
You definitely upset the apple cart ;-). Thank you so much for all of your info.
bobo123
16
Thank you so much! I am going to copy your response and share it with my father so he can benefit from your experience.
RogerDS
17
I own a QIDI Tech 1, and my brother has a Flash Forge Creator Pro. I used his Creator Pro before I purchased the QIDI Tech 1, and thought that the Creator Pro was very nice. It prints fast enough and nice, but so does the QIDI Tech 1. But since working on my QIDI Tech 1, I have found some advantages; it has a “high resolution” setting, which takes all the guesswork out of having to change settings. They will both print two colors, Creator Pro has to have the two files merged into one file before it will print, while the QIDI Tech 1 combines files in a similar way it seems to work faster. The QIDI Tech 1 has a more extensive onboard menu. Both show the cooling fan mode in its present state, the opposite of what you might expect, where it shows “Cooling Fan On”, it is “Off”, and must be turned on for each print. One thing about the high resolution setting. Larger objects seem to encounter problems. More Later.
Roger
Not my intent to hijack this thread…but while QIDI fans are listening
when I connect to my QIDI via USB to my it is not recognized - at all. Meaning nothing at all happens (no new device recognized by the PC). My only way to use the printer is via the SD card. No big deal, just wondering if I’m missing something?
Also is there a guide somewhere for the Sailfish to fine tune the calibration of the printer? Lots of menu options that I’m not finding explained anywhere. Thanks, and for whatever reason Google doesn’t seem to like me recently.
RogerDS
19
Try disabling your firewall and Windows Defender. Then install the software. If it shows, but will not connect then Go into your Control Panel, and select Printers and Devices. See if your printer is coming up there. If not try installing a new device. Once it installs the new device look at “Printers and Devcies” to see if it is there. You might have to go into properties to select the com port. My QIDI Tech 1 was a problem at first, but I received help here. My QIDI Tech 1 came up on “Com 3”. Use “Replicator Dual” as the printer selection. The slicer type is the replicator 50, or something with 50 in the selection. I do not have it on this system, because I am at the Phoenix College Library.
Roger
If not work from there.
I wish the hood was taller. The feed tubes and cable rub and push hard on the upper lip in the back. If you shorten the tubes so they don’t rub then they are really starting to stretch on bigger prints. I usually do not engage the rear clips on the corners but let them sit up on top to gain a little more clearance but then have to tape things up to fill the gaps.
MakerRx
24
Flashforge released a redesigned model in 2016. It’s probably the nicest makerbot clone out there now. They got rid of the laser cut hood that you assemble in favor of a solid formed hood. They also added an active cooling fan for PLA printing. Full disclosure I’m a US reseller but if you want to buy one through me I can help you guys get into the 3D printing world… cost effectivly https://www.makerrx.com
