Sep 2015
Could someone tell me if it’s possible to 3d print PVC? If not exactly that material, would there be a suitable alternative. I need a replacement part (made of PVC) for my shower.
Thanks
    Sep '15
    Sep '15
  • 8
  • 1.2k
  • 5
As far as I know, there are no reputable sellers of PVC filament, as PVC would be dangerous to use in a home FFM 3D printer.
If PVC exceeds its degradation temperature and burns, it will release very toxic chlorine gas.
Also, it is difficult (but not impossible) to make a water-tight FFM part.
That being said, your best bet would be to make a part of out ABS, then ‘solvent polish’ it by a quick 5-second dip in acetone to make it water-tight.
Thanks you the man! I’ll start looking for a printer! Anybody reading this thread willing to help me scan, adjust, print and dip this with me? I’m based in Amsterdam.
http://www.lairdplastics.com/product/materials/petg 1
PETG
Polyethylene terephthalate (aka. PET, PETE, PETG) is a plastic resin of the polyester family that is used to make beverage, food and other liquid containers, as well as for some other thermoforming applications. PETG is a clear amorphous thermoplastic that can be injection molded or sheet extruded. It can be colored during processing.
Properties
PETG can be semi-rigid to rigid, depending on its thickness, and it is very lightweight. The main virtue of PETG is that it is fully recyclable. Unlike other plastics, its polymer chains can be recovered for additional useIt makes a good gas and fair moisture barrier, as well as a good barrier to alcohol and solvents. It is strong and impact-resistant. It is naturally colorless with a high transparency.
Applications
PETG is used as a Midrange priced product between Acrylic & Polycarbonate. The clearity of PETG approcies that of Acrylic & Impact Resistance of Polycarbonate. Also is used in Signing, Glazing, POP Displays, etc.
