May 2016
I’m new to the form so please bear with me. I have a Divinci AIO that’s been flashed and I’m running Repetier host. I was trying to find information on installing my PT 100 sensor but I couldn’t find any documentation that could help me with my printer board. If anyone has done this I would greatly appreciate any information. The more detail the better. I have no idea where to attach the sensor on the specific board. Please help.
    May '16
    Jul '16
  • 7
  • 1.3k
Look at the pin.xlsx file, find an analog pin. Change firmware temperature pin # to match the analog pin #.
I worked with Repieter to get this working via the Repieter configuration tool but you should be able to alter your firmware to this.
You can probably get luc-github to help you, he is the guy who mapped all the pins and modified the firmware.
Soliforum is also a good place to see if someone has done this before.
I did. I’m all ready to go as far as that’s concerned. A little nervous about the possibility of having to use my soldering gun. I was hoping for an existing set of pins. I haven’t had a chance to read the information was given in this thread but I just wanted to say that I appreciate the help.
Well, I looked at the xlsx file and I still can’t figure it out. I was wondering if there was a way a way to bypass with an Arduino Uno? In other words, run the pt100 through the arduino to the Da vinci.
1 month later
If there are open analog pins on a Davinci board and you get the kit with amplifier then wire the signal wire from the amplifier board to the open analog pin then wire the power 5v and ground to the amplifier board. Then edit the temp table in FW.
