3Dcz
Hi all,
I have mistake with 3011 / 3013 (they change each other).
I have done everything I need in the instructions.
- Set 5 new heads.
- Lubricated all rails, cleaned etc.
- Changed on new POGO PCB and Pogo Flex Cable.
- Took on to check another E-box and Festoon cable.
Problem still exists. After flashing firmware the date is lost, how to return the current date and return the printer to print?
03/06/19 13:19:20 0 19 Printer: Rev: 5.243 May 9 2013 16:22:09
03/06/19 13:19:36 0 19 Printer: PCBINFO: ZPrinter 650 Add-On card serial number does not match flash drive record. Updating record.
03/06/19 13:19:36 0 19 Printer: PCBINFO: previous value: 6601xxxx-574DF5C9-04, new value: 65111xxx-54B65573-04
03/06/19 13:19:36 0 19 Printer: PCI v323, AddOn v234, Pogo v320
03/06/19 13:21:31 0 19 Printer: Empty overflow canceled, recovered less than 0.05 inches
03/06/19 13:28:59 0 19 Printer: Smart purge started
03/06/19 13:28:59 0 19 Printer: purge heads 0.000e+000 pixels
03/06/19 13:29:02 0 19 Printer: Smart purge took 0.03 minutes
03/06/19 13:29:17 0 19 Printer: start job
03/06/19 13:29:17 0 19 Printer: pixel count:0:50348965888 1:6299090944 2:8028037120 3:8598970368 4:5633474560
03/06/19 13:29:50 0 19 Printer: CheckHome fast LM629:2 SEQ:-1
03/06/19 13:29:50 0 19 Printer: StartJob waste bucket is 26% (990 grams) full
03/06/19 13:29:52 0 19 Printer: SEQUENCER: Timeout, SeqStatus:0x14, SeqIRQ:0xc007, PogoCtrlReg:0x1e5
03/06/19 13:29:54 0 19 Printer: SEQUENCER: Timeout, SeqStatus:0x14, SeqIRQ:0xc007, PogoCtrlReg:0x1e5
03/06/19 13:29:54 3013 20 SEQUENCER: timed out finishing swath, flags = 14
Date broke
05/21/09 00:00:22 0 19 Printer: Rev: 5.243 May 9 2013 16:22:09
05/21/09 00:00:40 0 19 Printer: PCI v323, AddOn v234, Pogo v320
05/21/09 00:04:30 0 14 Monitor: (00:04:30) TLV2556SPI: comm successful after 1 retries
05/21/09 00:04:30 0 14 Monitor: (00:04:30) POGOFIFOSPI: comm successful after 1 retries
05/21/09 00:04:30 0 14 Monitor: (00:04:30) POGOFIFOSPI: comm successful after 2 retries
05/21/09 00:04:30 0 14 Monitor: (00:04:30) ADC conversions thrown out [test registers: 4095 4095 4095]
05/21/09 00:04:30 0 14 Monitor: (00:04:30) POGOSTATUSSPI: comm successful after 1 retries
05/21/09 00:04:30 0 14 Monitor: (00:04:30) HP11BROADCASTSPI: comm successful after 1 retries
05/21/09 00:04:30 0 14 Monitor: (00:04:30) HP11READBACKSPI: comm successful after 1 retries
05/21/09 00:04:30 0 19 Printer: (00:04:30) SEQCONTROLSPI: comm successful after 3 retries
05/21/09 00:04:30 0 19 Printer: SEQUENCER: fifo underrun, SeqFlags:0x424, SeqIRQ:0xc306, PogoCtrlReg:0x155
05/21/09 00:04:32 0 19 Printer: SEQUENCER: Timeout, SeqStatus:0x14, SeqIRQ:0xc007, PogoCtrlReg:0x3e5
05/21/09 00:04:35 3013 20 SEQUENCER: timed out finishing swath, flags = 14
I have no idea, had the same issue. I’ve all but given up on this horrible machine… I’ve tried flashing the firmware, reseting the board but to no avail.
If you can think of anything else, please let me know I can try it!
Thanks!
If the Pogo and Flex cable are both brand new, the next step is replacing the festoon cable assembly.
