Mar 2016
Just as FYI, parts off the 660 “can” be made to be as strong if not stronger than what most of you are thinking. I’d imagine that most of you are using the “crazy glue” cyanoacrylate color bond. Which only penetrates about 4mm-5mm into the model.
I’d recommend going out and actually trying other liquids that have as low of a viscosity that will make the models even stronger. Hell you can use a 2 part epoxy or even a thremocure material like XLA Form (This is at least 5+ years old https://www.youtube.com/watch?v=TJauNmL9vmw 9) as alternatives infiltrants. Because these liquids take longer to cure the plaster continues to absorb even further. I mean how many of you have a convection oven to even dry the models? Don’t think that letting the model cure in the powder in the machine is the same as just leaving it out and immediately infiltrating. It’s not the same, it doesn’t feel the same and it most certainly doesn’t absorb the infiltrant the same. (depending on wall thickness).
It really bugs me that the perception of the models off the x60’s are that they are fragile and will always break. Do your homework, if the model is too fragile to pull out use the option to “make fixture” found under the tools menu. Then you can pull the model out by the fixture which ups the survival rate if you can’t get it out otherwise. Is this extra work, yes, but where’s it written than making models is supposed to be like microwaving popcorn…
AIS has a customer running a 660 24/7 since November with no service calls. We may also be able to help you with service on your 4500 if you are in the SoCal, NV, AZ or UT area. 702-951-4247 x288
Hi we have a 660 and It is very riable. Unfortunately we are closing our 3D area for other problems and we would like to sell it. If are you interested in, please let us know.
Bye
Giampiero
