Today I printed a Day 1 case and it had similar problems as I already found in other cases. See pictures.
This makes the Hubs’ job a very difficult one because people who order a FairPhone case and get in contact with 3D printing for the first time don’t know what they can expect. They assume the case is as smooth as a cast case which of course isn’t the case !
The case needs (unnecessary) cleaning which doesn’t make it prettier!
@rooiejoris can you please do something about this? The reviews for FairPhone cases come up with 5 stars for everything exept the print quality! This is not good for the Hubs’ reputation! Please also have a look at other threads about this issue.
Tomorrow the elephant will be finished at schiphol, so next week I can spend some serieus time reading all the comments, sorry… [www.stapvandeolifantaf.nl]
I just had a quick look at the pictures, but this is a different problem than discussed before no…?! This is all about the bridging problems. In my experience that you get better bridging when printing colder. Advanced tricks could be to hack the gcode and place manually a M104 S… for you favorite temp setting. or print the whole casing colder [but that may result is a less strong casing].
Another option is to print with support, but i don’t really like that personally. Maybe i can add a support in a future stl, but then somebody has to test that as well…
The other problem i coulnd’t find [with the loose parts near the top]. I have the feeling that it has to do with layerheight and bad luck getting exact the wrong horizontal plane at the wrong height. I willl check the file and maybe make it less horizontal.
Can you send the gcode or settings ini so i can check with the same parameters…
When you add support in Cura it will not print because it is to narrow (I think). The best way would be to add some support in the model so the bridging problem disappears. This is different with every filament so hard to figure out if you only print a few cases per color and it will take a very long time also.
This problem is different because it’s a different case but they are all the same kind of issues. I tried also different layer heights but that doesn’t take the problem away.
The loose parts near the top of the holes are really printed so they have to be removed and they probably also interfere with the bridging, causing the mess.
I’m happy to do some testing on the changed designs if that can help!
Here I can’t attach the ini-file I use; can I mail this to you?
I took a look at the stl of day05 and found some extra faces which could be the problem. I manually removed them, so if it works i can repair and upload new stl files for the other days as well…
i also opened it in meshmixer and removed a ‘seperate shell’ [whatever that may be] and it seems to be solved as well. That could save me a lot of handwork where i can make misstakes if it works…
[alterations]
start.gcode = ;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
G92 E0 ;zero the extruded length
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing…
end.gcode = ;End GCode
M104 S0 ;extruder heater off
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
M84 ;steppers off
;{profile_string}
start2.gcode = ;Sliced at: {day} {date} {time}
;M104 S{print_temperature} ;Uncomment to add your own temperature line
;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line
;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
T1 ;Switch to the 2nd extruder
G1 F200 E10 ;extrude 10mm of feed stock
G1 F200 E-{retraction_dual_amount}
T0 ;Switch to the first extruder
G1 F{travel_speed}
M117 Printing…
end2.gcode = ;End GCode
M104 T0 S0 ;extruder heater off
M104 T1 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
M84 ;steppers off
;{profile_string}
start3.gcode = ;Sliced at: {day} {date} {time}
G21 ;metric values
T2 ;Switch to the 2nd extruder
G1 F{travel_speed}
M117 Printing…
end3.gcode = ;End GCode
M104 T2 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
start4.gcode = ;Sliced at: {day} {date} {time}
;M109 T2 S{print_temperature2} ;Uncomment to add your own temperature line
G21 ;metric values
T3 ;Switch to the 4th extruder
T2 ;Switch to the 3th extruder
G1 F{travel_speed}
M117 Printing…
end4.gcode = ;End GCode
M104 T3 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
support_start.gcode =
support_end.gcode =
cool_start.gcode =
cool_end.gcode =
replace.csv =
preswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added before the T(n)
postswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added after the T(n)
It did some tricks, I don’t see the problem explained on page one in “FairPhone case day 5.pdf”. That was the most visible thing if i understood right…
Attached a non optimized stl file, cab you check if this also have these small misstakes…? maybe meshlab screws up something when removing faces… day05_uncompressed.stl (96.3 MB)
indeed the problem described in the PDF didn’t show in the former version anymore.
This last file doesn’t show any mistakes! So probably something goes wrong compressing the file?
It’s probably best to send the uncompressed files for all the models to all the FairPhone Badge holders so they can use that one for the actual printing.
I will take a look on the support, that shouldn’t be a problem, thats why i started with the “strange” things…
A possible problem with the uncompressed file is that the path length can get so short that you are unable to print in a nice speed, but you will notice that during printing.
