I am a Delta printer novice. Since I tried to upgrade the firmware on my Atom 2.0 delta, the printer is doing strange things such as:
when I try to do an AUTO LEVEL the effector only moves part way down and begins to sample points in space well above the bed. After the first point, it moves across but UP to continue sampling (it would seem that there is something wrong with the Z movement). It continues to do this for each point and so finishes sampling at a point much higher than it started!! The effector appears to be moving to the correct X and Y positions. Needless to say, if I try to print, printing begins way above the bed. The problem began when I removed the nozzle to clear a blockage then decided to upgrade the firmware. I purchased this printer second hand and it was working perfectly before this. Any suggestions? Is there anyone in the Sydney area who works on/repairs Delta printers?
Thanks
Brian
created
Oct '16last reply
Oct '17- 1
reply
- 1.1k
like
- 1
link
