Jan 2017
Good morning,
i bought a few days ago a WANHAO Duplicator i3 Plus and it work very well but i have a problem.
I use Cura (provide with the 3D printer) and when i use the plugin “Tweakat z” (for change the filament) it goes into the correct position but it doesn’t stop printing. It continues to print.
Why?
How can i solve that?
Thank you so much.
    Jan '17
    Jan '17
  • 1.3k
  • 3
I’m not clear on what you are trying to do, but I would guess that you are wanting to pause the print job so you can change to a different filament? If so, Tweak at Z does not do that. For mid-print filament changes, I normally edit the GCODE, but the Pause at Height plugin looks like it may do what you want to do.
please find attached a link that will help you out.
I don’t actually use the “Tweak At Z” however I could look into it if you required?
Let me know now if you need any more assistance
Many Thanks
